hey is this pulley ok for my ssm90 setup?
DBGP
hey my ssm90 kit awaits to be put on my car. I got a gtp belt setup for it, and i have a stock gtp pulley (3.5 correct me if im wrong.) Would that pulley be fine? My mods will be 2.5" dp, ubend delete, mufflers, CAI, ported LIM and s/c. If its too small i would just order a ssm90 pulley from zzp, if i did i would get the 3.8. On their site it says all ssm90 pulleys the same as a gtp pulley .3 smaller? or is that bs? Im just tryin to make sure here i dont want my KR to go though the roof. thanks
many find you need headers just to run the top swap with the stock 3.8" pulley...
leave the stock one on but get headers.
Ok thanks! Yea next upgrade will be headers, colder t-stat then I can maybe drop my pulley abit
3.6 is about the best you can expect from a top swap with headers as your only mod.
I'm running a 3.8 on a top swap with headers, ported TB and S/C.
Yea 3.6 is what I had in mind, where the gains noticeable compared to the 3.8? Also how's the ported TB? I've been wondering on if I should get one or not.
You attempt to smooth out the MAF hump in the TB.
You'll need a street tune if you do it.
Helps with throttle response.
From the sounds of it, you are looking to just run a regular pulley on a ssm90 kit?
The ssm90 kit uses special pulleys. You cannot use stock pulleys as you need the belt setup for that. You would need the balancer or crank pulley from a gtp and the idlers/ tensioners/brackets to run a supercharger belt.
I would start off with a 3.8 pulley or higher and go from there.
ok yea il just run the stock 3.8 pulley, i have the belt setup for my m90, i have all the tensioners i need. thanks guys
