DexCool = Old Bay Seasoning
SlowNA06
Mild concern, no performance issues.
Full coolant flush a few months ago, fresh DexCool. Checked the coolant yesterday. Was a little low... the cap seemed to have some Old Bay Seasoning on it. Old Bay Seasoning seemed to cover the whole couple inches down to fresh clean coolant. I wiped it all out and cleaned off the cap... topped it off and poured a little more into my overflow, which was a bit low.
Is this just DexCool reacting with oxygen because it was a tad low?
Anything I should be worried about?
It's the DexCool eatting away at your gaskets. If you feel up to it do another realy good flush & reaplace that DexCool with the Green stuff. As for the coolant being low you could have a leak.
FYI, dexcool doesn't "eat" gaskets. Poor LIM gasket design causes them to crack, letting dexcool react with air and then sludge.
It's the DexCool eatting away at your gaskets..
nothing like straight up ignorance
THATS more like it!
http://www.automotiveforums.com/vbulletin/showthread.php?t=958284
you're really gonna tell me thats not poor design?
coincidentally mine failed in the exact same spots....
i was having a problem similair to yours.. i'd lose about a half gallon of coolant every few months, and could not figure out where it was going. turns out it was mixing in with the oil, and being evaporated.
what gave me the idea was i always cut open my oil filters, and recently they looked like sh*t, suggesting there was moisture getting in there somehow. cut open your next filter, if it looks anything like this (wavy/warped pleats), youve got moisture in your oil.
I lost more like... maybe a quart, tops, since my flush in June. I wouldn't be surprised if some of that was from air settling out. I'll be sending out an oil sample in a few hundred miles, so I may as well check the filter before I chuck it.
Another point, I believe the 04+ might have a new generation LIM gasket... think the GM recall thing only went up to October 2003 or so. Edit: I think I was thinking of the target time period for the "class action suit" or whatever it was.
Nonetheless, something to get fixed before it starts breaking other things.
The only recall was for the spark plug holders and the valve cover gaskets in the 97-03 cars. GM did however, start going with the aluminum ones from the factory in 2004 cars (L26/L32) IIRC
Wow, I must say that report is a little concerning. If I’m following the story here you changed the Dexcool right on schedule (maybe even a little early) and you probably have a LIM gasket failure. What year is your car, an 06? Arrrg.:th_nervous:
Naw, this is for an '04. My '06 is a happy little peach.
I wasnt expecting a link. I was just amazed that people claimed aluminum LIM gaskets failed. Unless the engine was overheated badly, I dont see a reason why aluminum LIM gaskets should fail at all...
