Tranny fluid disappearing?
jokyfo
1994 3.1 Automatic tranny 4 speed
Using tranny fluid. No leaks under car (not when just sitting and running anyway).
Where else can tranny fluid go?
Thx
It's kinda tough to diagnose a leak while driving from here. You are about 3,000 miles away and it's tough to see if the subframe and underside of the car is wet. Know what I mean? :th_winking: You need to do some looking and investigating to help us out here. You are our eyes, ears and hands.
To find transmission leaks you'll need to drive around then park it and check all the lines. The lines are under a lot of pressure and the leaks only appear when pressurized.
The lines should be wet if leaking. Running or not, if it's leaking enough to notice on the dipstick then it should be visible.
