HID harness install ??
chunky
Banned
i picked one up from W-body store but have no idea how to install it, here are the 3 ends, where do i hook them lol? i assume the red and black go to the battery, but i'm not sure about the blue one.
oh wow, that looks like the connector for your headlight bulb....
lets see the entire harness though.
They're all different and all screwy.
Well I know the red and the black go to the respected positive and negative terminals on your battery. Depends on the harness but the on the other ends, one should connect to the ballast and the other one should connect to the bulb, its that easy. If i remember it correctly...:th_shakinghead1:
Yessir.. red goes to battery, black is for ground. That blue one goes to where your stock headlight bulbs were. There should also be one more connector on the relay harness. This goes to the ballast, then the ballast connects to the HID bulb and you're set!!
that one is differnt from my relay harness. I have like 5 ends to mine lol...and it looks like it's similiar to re-wiring the electrical lighting system. looking for a way to connect it to mine lol
I have a feeling i know what urs looks like. post some pics up and i should be able to help
should of bought a cheap japanese set,i installed a set on a cavy tonight,just plug and play no wiring to the battery at all and they are super bright.the hardest part was deciding where to mount the ballasts.
You still want to install a wire harness. Look at the specs for how many volts it takes to start the ballast up. It aint small so you want to go for wiring them up to a harness
csssaint...thanks for that diagram. I duno why I was dreading it. just wired up the harness and hide it well. It was toooooo easy. but without your diagram I would have ran that one end to the fuse box !:th_nervous:
Now I wait 'til dark to get you guys some pics. hopefully they are alot brighter and I wont have to do what Matt posted and modify my bulbs :\ I don't wanna go there.
no problem dude. always glad to help. let me know if for some reason that doesnt work. cant wait to see the pics
