hello new comp -g owner
nfamous
So i bought a new (old) 04 gtp comp g looking to see how fast it is?
Mod list :
fully ported heads and blower ect.
16.85 lbs max boost
cai 85mm maf
xpz cam push rods pedistals
stage 4 zzp heads
comp cams roller rockers 1.7
roll master double timing chain
stage 2 radiator/pump ic kit/gm 100,000 silent
easy performance fuel rails
arp head studs
modular pulley hub gen 2
2.55 pulley
machined snout
mototron 65lbs injectors
tech edge iccu screen
mls .052 headgaskets
clear water pump pulley
tech edge fuel pump and altenator re wire kit
tech edge egr slim and block offs
autolite 103 plugs
tog extreme titanium cooated headers
8-rib crank pulley
8-rib converion pulleys
8-rib belt
custom exhaust 3inch from header to mufflers (was 3 inch straight thru)
built zzp trans 2500 stall zpak ect
3.69 gears
dhp custom pcm
ga brake conversion
cutout
stage 2 axles
aero force gauges ect...
wizaired
so with all this what do you think i would run?:th_nanana:
i have a dyno sheet but i changed the exhaust so i would have to see the new results? new to gtp's
thanx it's a nice car i'll have to get some pic's up it has a wizaired to what ever that is
sorry im a gtp noob
you bought a car with such an extensive mod list and you dont know what a "wizaired" is?..oh boy, you got ALOT of reading to do ;)
low 12's if you can drive if not youll blow the tires off and get a 13.0 @115
^THIS!!!
I'll let you pass on not knowing what a Wizaired is... but Im hoping you know what the rest is, and what you were purchasing......for your wife:th_shakinghead2:
yes i know what the rest is she drives my 500rwhp cobra 01/termi swap.
(btw i googled it it's a cai) anyrate fun car quick as hell just seeing what people thought of the setup since this is my first gtp.
Yea for a dd that is gonna get kinda bad gas mileage, especially with 3.69 gears. and im not sure but 16.85 lbs of boost sounds pretty high to me...
for these cars 107 is low when idling.
ga brake conversion
LOL you had better get at LEAST an F body setup on that thing ASAP.
The grand am brakes will definitely do nothing to slow that beast down.
Ill have pics up tonite of both not a troll and their not imaginary lol
gp is black with tinted windows chrome gpx style rims
cobra is an 01 s/c w/ported eaton true blue my favorite of all cobra's
pics of cobra can be seen at svt performance. or will have them posted tonite lol:th_laugh-lol2:
