Catalytic Converter Removal 99 Grand Prix GT Coupe *HELP*
blortz
so due to my catalytic converter being clogged i am now removing it but my uncle tells me that its going to cost alot with getting a shop to do it and the welding and what not..... whats the cheapest route i can go?? i have already ordered an O2 Emulator from ZZP Performance. Its in thew mail.
So I want to remove my catalytic vonverter.... What is the easiest and cheapest way to do this??? i will eventually put on flowmaster mufflers with alll new exaust
HELP!
Re: Straight Piping 99 Grand Prix GT Coupe *HELP*
i would advise against straight piping. sure, delete your cat if you want, but your car is gonna sound like crap without a resonator or mufflers.
sorry thats what i mean ...i just want to remove my catalytic converter......
yeah see my girlfreinds uncle is going to do it... he will take off the down pipe and remove it and use a straight piece of pipe and weld it on... but he said it needed to be bent?? or soemthing..... i think that would be costly... he is also replacing one 02 sensor and i have an emmulator...
Why would you replace the o2 sensor if you have an emulator...unless you mean your replacing the top o2. Also...nothing needs to be removed DP wise...he just needs to cut out the cat/u-bend...weld in the piece of straight pipe...and done. Zip tie your emulator to your frame or something...and throw out your old rear o2. Problem solved.
HELP!
Your uncle is correcr. You need to spend much money on it. But one way to lessen your expenses that if you have an acquaintance that gives you discount. :D
What parts do you need to gut a cat besides a BFSD you don't care about?
I see the labor...but parts? LOL Cut out cat...gut it...reweld.
