ZR1Vette09
Resident HOMOsapien
Many people who are new to a forum make their first post a question about a problem. In an effort to keep the forum clean (with minimal repeat posts) please take a look at some of these threads that may answer your question!
Modification threads:
Feel free to send me links for other important threads. I am only able to work on this thread a little bit at a time so not everything has been included yet. In order to keep it neat Please do not post links in posts below, PLEASE PM ME TO ADD LINKS!
- For general modding information, see our "Safely Modding your 3800" thread. http://www.grandprixforums.net/safely-modding-your-3800-powered-car-17482.html
- Header information. Here you can find a list of pros and cons of each brand as well as a link to where you can buy them. http://www.grandprixforums.net/header-manifold-thread-25922.html
- For the Naturally Aspirated (N/A) guys, here's some information on a "Top Swap." This is where you literally swap your top end for a supercharger/blower. You'll find a parts list, as well as some technical info and installation instructions. http://www.grandprixforums.net/top-swap-info-faqs-also-lots-3800-info-7763.html
- Transmissions. Yeah, they have problems on these cars, you're not alone. This is a link to one of our vendors, Triple Edge Performance, who is very reputable in rebuilding/upgrading our tranny's. http://www.tripleedgeperformance.com/
- Lowering Thread. You can find a list of brands and pictures of how different setups affect ride height. http://www.grandprixforums.net/want-lower-your-car-look-here-28165.html
- Open-cone vs. Cold air intake. Dyno runs of each to support the effect of either setup. For more detailed information on intake setups take a look at the How-To tab. http://www.grandprixforums.net/dyno-science-cai-box-vs-open-cone-intake-33225.html
- Information on how to fit wheels, tires, offsets in here: http://www.grandprixforums.net/got-some-wheel-questions-here-29622.html
- A list of Check Engine codes or Service Engine Soon codes (SES) is available here:http://www.grandprixforums.net/dtc.php. When you have determined the code title, it should be easier for you to search the forum for other people with the same problem.
- The infamous "Water in Passenger Floorboard" for 1997-2003 body style. http://www.grandprixforums.net/water_floorboard.php
- For the 2004-2008 guys, here's some information on your water leaks. Post number 4 describes one issue, post number 5 describes another issue. Be sure to check both. http://www.grandprixforums.net/water_floorboard.php
- Coupler's are known to go bad on your M90. Here is a reference for a repair How to replace an M90 snout coupler without removing the entire blower.
- 2004-2008 Radio Light/LED's are known to go bad. Here is a link for the very simple repair. http://www.grandprixforums.net/radio-backlight-out-37475.html#post440494
- 1997-2003 Crankshaft Position Sensor repair. Fairly common, the telltale sign is a tachometer reading 0 RPM http://www.grandprixforums.net/cps.php
