Supercharger ACTUATOR???
I took mine off my old s/c to put on the new s/c and it works fine and I didn't adjust anything.
The actuator is the round deal with the plunger deal coming out of the bottom. Most people call that the boost bypass valve. The BBV is actually the little box below that has the electrical hook up.
No, thats the solenoid.
The actuator is the giant cylinder on the side that closes the valve, the bbv is inside the case.
So basically the OP forgot to mention its the BBV actuator.
Go to the dealership and ask for one. See what they say, that's where I got my information.
depends on how its broken.
if its stuck closed... you can easily get into boost.
if its stuck open then you're stuck at 4-5 lbs of boost which isn't bad at all.
This is true, guess when I think broke I just think that it is stuck open.
