Guys for the digital dash thing use the search
digital climate control hack
Street Wolf
Banned
My Garage
Chats: 82
Re: 97-03 Climate Control Hack
To enter diagnostics mode:
Press and hold both the Driver and Passenger knobs in simultaneously until the display changes to read "-00". To change position, turn the Driver knob to the desired number and turn the Passenger knob one click to view the data for that position.
Position Description US Observed on mine Canada
-00 Error codes (List of Trouble Codes Below!)
-01 (servo position) 103-107 43-162
-02 (servo position) 128 120-202
-03 (servo position) 150 162-194
-04 CJ2 Fan Speed Low=15, 29, 44, 58, 71, 86, 110=High, CJ2 Unit will adjust to other increments as needed
-05 (servo position) 93 88-191
-06 (servo position) -152 00-252
-07 (servo position) 00 0, 34-255
-08 (servo position) -155 00-255
-09 (servo position) 00 0, 23-255
-10 ? 04 04
-11 CJ2 Vent Mode 1=Def, 2=Bilevel, 3=Auto, 4=Lower, 5=Def+Lower
-12 Engine Coolant Temp -60 degrees 80=104, 95=131, 100=140 Peak@135°F
-13 Actual Vehicle Speed in MPH
-14 (servo position) 00 21=0
-15 ? 39 44
-16 Radiator low fan turn on temp -106 207
-17 Radiator low fan turn off temp 196 199
-18 ? 50 51
-19 (servo position) 162-169 40-172
-20 Affected by cabin temp sensor 89 50-172
-21 (servo position) 00 ?
-22 Sunload Sensor -117 LIGHT=126, 218=DARK
To return to normal operation, press the MODE button next to the Passenger temperature knob.
This is a list of the Trouble Codes displayed by the CJ2 Unit.
A two digit code indicates a current fault while a three digit code indicates a historic fault.
Trouble Code Description
00 No System Fault
01 or 101 Inside Air Temperature Sensor Short
02 or 102 Inside Air Temperature Sensor Open
03 or 103 Ambient Outside Temperature Sensor Short
04 or 104 Ambient Outside Temperature Sensor Open
05 or 105 LH Electric Actuator Open or Short
06 or 106 RH Electric Actuator Open or Short
07 or 107 UART Serial Data Line Fault
08 or 108 Solar Sensor Open
To clear codes from the CJ2 Unit, press the A/C Mode button.
