Wraith888
I have a piece of trim that fell off the bottom one of my rear doors. It's the piece on the bottom that slides into a metal groove and is glued/taped to the door. The body shop that painted the door painted the door and then used glue or silicone to attach the trim, but it fell off during a really really cold MN winter day last year.
I was told to use 3M foam tape to reattach this. My plan was to get some of that 3M gunk removal and then if that doesn't work, get a razor blade out. If I scratch anything, use black primer (since it won't be seen behind the panel anyway) and cover it to protect against rust. Then pick up some black 3M tape and attach it after cleaning the surface with alcohol. I'm thinking if I can get the rolls of tape I can use those to make a continuous strip to attach, is that the best idea?
Any advice welcome. Thank you!
