kirkkarem1212
are Screamin' Demon coil packs better than stock? worth the money? are they even offered for grand prix?
any advice on what coil packs are best? i heard MSD are crap
Though the stock GM coils are known to produce plenty of spark power, the Screamin' Demon coils are designed to produce exceptional spark power with no drop in power at higher engine rpm (5,000-up)
We felt smoother throttle response but didn't see an improvement on the dyno. However, the upgrade in materials and durability over stock are better reasons to use these products than a possible gain of a few horsepower.
Performance Distributors had just released its LiveWires (PN C9043, $89) and Screamin' Demon coils (PN 31735, $99) for the '95-up 3800 front drivers.
Screamin' Demon coils employ a brass terminal to attach the coil wire. According to the company, the brass terminal is more conductive than a typical aluminum terminal and will resist corrosion better. Increased coil energy allows for a wider spark plug gap, which could increase power and mileage.
Though Performance Distributors ignition products have shown improved performance in previous strip and dyno testing on other makes of motors, back at SLP we ran identical numbers to our last pull on the rollers. This is possibly because, though Performance Distributors recommends increasing spark plug gap to 0.060 (due to the increase in coil power) to improve mileage and horsepower, the stock plug gap for the GP is already 0.060. Another factor is the power increase is generally found at 5,000+ rpm and our GP makes peak horsepower at just 4,790 rpm. Regardless, our intent was more to increase durability and reduce maintenance with these high-quality ignition parts.
I still say stock wires are the best. I had the Red Taylors for a year and half and they failed. Went back to stock with no problems ever since and the stock ones have a lifetime warranty.
Brother we are talking about coils not wires![]()
You could do a MSD DIS-4 set up but its pricey and has its down falls
So where can I get a set? And wires
Was the dis-4 worth it What did you notice over stock besides ability to munipulate timingThe only downfall for me was the wiring it in. :th_skull:
