I bought my kit from INTENSE (of course), and all my fittings, stainless steel hose, and the aluminum filter bracket from Summit Racing.
I have my filter now mounted on the sub-frame just infront of the starter mounted horizontally.
You will need a 90* and a 45* pipe thread to AN connector
You will need a 90* and a 45* swivel fitting connector
^thats all for the adapter plate
You just need two straight pipe thread to AN fittings and two straight AN hose adapters for the oil filter bracket if you go the same route as me, but do what you want. I have used these same brackets since my very first car, and love them to death. Nothing worse I hate than changing the oil, and making a mess because of poor engineering from the maker of the car.
You attach the 90* pipe thread to AN fitting to the 45* swivel fitting and the 45* pipe thread connector to the 90* swivel fitting. You have to position it just right where the CV shaft will clear them when it turns.
When ever my front cover comes off, I leave the fittings screwed into the adapter plate, and undo the swivel fittings from there. I then can remove the filter, and the lines to get them out of my way if need be.
For my oil pressure gauge, I got a little extender to get the sender unit out away from the adapter plate so I could get in there and adjust the oil pressure with out having to remove anything to do so.
There is still not a lot of room, but enough to do what you need to get done, done.
Because of the long lines to the filter, and the size of filter I use, I do not require any more than 5 quarts of oil to be at the top of the hash marks on the dip stick.
~F~
