3.4 Pulley System ?
AmericanRiceEater
Hey, i've been nearing the installation of a 3.4" pulley system. I've been looking into the 3.4" ZZP system for $99.99. I wasn't sure if it came with everything i need to install it, or would i need to buy anything extra like a belt ? The garage im going to has a puller so i won't be needing that. Please help me out. Also if you have a complete system for sale please look into my thread in the Buying/Wanted Forum. Thanks a lot ! :th_thumbsup-wink:
So if i was to order everything right now to install a 3.4 pulley system from ZZP, what's everything i would need besides the tools ? Just the 3.4" ZZP Pulley System and a belt or is there more? Thanks a lot :th_thumbsup-wink: (This is my first time dropping a pulley size in any kind of car.)
yes you need a new belt along with everything in the kit, is the car tuned and modded to support the 3.4?
Ya it will be by the time i go to install the 3.4" sometime next week. So i'll have everything i need after buying a new belt and the zzp pulley system ? Thanks, again you're a help.
A tune from the shop, or a tuned PCM ? I can imagine ill need both lol. Im ordering a tuned PCM from Reptile later this week, and will probably have an overall tune done at the shop once i install a 3.4" pulley. But im just re-assuring myself that im not going to be ready to take my car in for the pulley swap and have to order more things for the pulley because the zzp pulley system and belt won't be enough, or will it ? Thanks.
You know without a scanner your not going to know, I have seen people drop to a 3.4 with what you have plus a tune and still have knock and others dont. On the PCM side with Reptile tuning, you should be good to go. I would still highly suggest you scan before you go off and do any WOT runs with the new setup.
