Ok so new to the forum and need help
Slowburn
Ok so like the title says I need some help, I'm looking to upgrade to Hid but im just having trouble finding the kit and relay harness idk whats good and what works so if someone could post links for whats good and what works that would be awesome i have a 99 gtp with stock housing thanks in advance for any help :th_thumbsup-wink:
OK, here is what you want.
I have them off of VVME.com,
9007 HID Conversion Kit For our cars its the 9007 bulb. You can also get the HI/low beam combo too for a higher price: http://www.vvme.com/hilow-one-beam-in-hid-hid-kit-90072-hid-conversion-kit-c-44_53_50.html
I have the single beam kit with the relay harness on my 2000 gtp in the stock housings. Which is this one: Standard 9007 HID Conversion Kit Standard 9007 HID Conversion Kit,car lights [VVME-HKS97-STD] - $39.99 : VVME.COM, Car Parts, HID KIT, Tattoo Kit, Ballast, Bulbs
They are very good and work great, the light output is awesome and the install was kinda easy and for the price you cant really say much.
9007 HID Conversion Kit For our cars its the 9007 bulb. You can also get the HI/low beam combo too for a higher price: 9007-2 HID Conversion Kit
ok so i opened the second link and there are four to chose from i would prefer the 2 beam so i could have hi/lo beams still and do those kits come with the harness?
I dont know for sure, I read the describtion and everything and it didnt say anything there, but maybe some one esle knows.
If it does not the relay harness is only 10 bucks more. Relay Harness For Hi/Low HID Kit Relay Harness For Hi/Low HID Kit hid kit [VVME-HRHHL] - $9.99 : VVME.COM, Car Parts, HID KIT, Tattoo Kit, Ballast, Bulbs
Ok so I kno I want the harness and 8k but I guess I gotta fiqure out what the difference is between standard, digital, 12v, and 24v thanks for ur help
Well, in case you still wanted to know the difference, here is the link to the Difference. HID Xenon Kit Comparsion : VVME.COM, Car Parts, HID KIT, Tattoo Kit, Ballast, Bulbs
Also, here is one with the relay harness... http://www.vvme.com/standard-90073-bixenon-hid-kit-p-126.html?cPath=44_46_37
And I second about what to do with the fogs?
I dont have fogs yet but someday here I will.
FOr the 97-03 models years the bulb size is 880. 880/881/893 HID Conversion Kit
It the same as the heads lights, they just plug and play. The only draw back is that some of these HIDS might melt the stock fog light housing. What people do is, they go to like autozone and buy a pair of fog light GLASS housings for 30-40 bucks and then you dont have to worry about the heat and melting.
if you have HID headlights and regular fog lights doesn't that look kinda not sexy?
ha ha very true that's why i want to upgrade the fog lights, now if I'm not mistaking shouldn't the glass fog lights from auto zone be a different bulb? and how do they mount them to the bumper? are they the same as stock?
