antenna removal
beckys2000gt
looks fast.... its slow:)
i guess im posting in the right section, if not, lol please move it.
anyways, i have this ghey antenna on my 2000 gtp, and i was wondering if anyone had a idea on how to remove it????
I have no idea. Must be an aftermarket one because I thought only the 1997 SE's had fender antennas, everything else was in the rear window.
yea but nothing that cant be fixed, right? maybe i should just cut the antenna off and let the little "stub" just there, idk..... its looks effin RETARTED!
I did that with my onstar antena. I dont want to buy a new rear windshield just to get rid of that stupid thing.
There's no hole in the window. Inside piece of the antenna is double sided taped to the glass and the outside is double sided taped to the glass. Just take them off, clean off the tape residue and tuck the wire behind the interior panel. You'll never know it was there. I took mine off before I had the window tint redone. The only reason they show a different part number for the backglass for the OnStar cars is because it comes with the two halves of the antenna pre-applied to the glass, the window itself is identical.
As for the antenna on the fender in question, you will probably have to pull back the trunk carpet on that fender and remove the nut holding the antenna on. Pull the antenna out and discard. Have the hole welded shut, bondo'd, sanded and the fender repainted.
Could be stock Gm did run out of the window defrost comb. ant. in late 2000 and used mast style for a couple of months
Thank you... This is coming off right now. :eek:
You could always get an antenna that goes up and down when you turn the radio on. My friend did that with his firebird and it doesn't look bad at all.
