injectors yet?
RICE KILLER
so i am running an xp cam with all the goodies, fwi, headers with a 3.4 and all the other basic sporting mods. i plan on doing either a N* TB or a ported stock TB, ported SC, and ported/polished LIM and hopefully drop to a 3.2 with a tune. so heres my question can i run the stock injectors or should i upgrade?
I ran stockers on a 3.1" and only went static when the 3.0" went on there...might have got lucky though.
Depends on how you tune it or how the car breathes, but I would just go ahead and look for some. Its better to have the extra headroom than to be worrying about it after you go static. Also, when you tune it, it could be close to static that day and the weather may change the next and you could go static again without even knowing. When the injectors go static, you go lean.
my 33's were on the verge of going static at a 3.5" but that was on a top swapped car if that makes any difference.
Yep mine are hitting 95 percent IDC on hot days. In the winter mine will probably go static(on a 3.5 also)
You can snag a set of 42.5'ers off of mustang/lightning forums...the green tops for cheap when they demod just a FYI
