Claude
Hey guys, I am hoping to pick your brains on a issue I've been having...
On my parents 96 Buick Regal, it has a starting problem of sorts. Where 60% of the time it starts fine, but that other 40%, you turn the key, and nothing happens, lights dim a very small amount.
Yes, you say that could be a host of issues. The starter is good (IE replaced a couple of times, trying to fix this problem), the ignition lock cylinder should be good (replaced trying to fix this problem).
The main battery cable, has juice going to it. It is the other wire, that seems to not get juice when it is suppose to (you can jumper it, and it will engage). The relay has been replaced, and the fuses look to be good.
Do you guys think there might be a short in the system? Where is the neutral safety switch, and could that be the problem?
Thanks for the help guys,
Claude
Claude
