I have a 1997 Grand Prix GT with 3800. Girlfriend tells me the other day the vehicle stalled out while driving. When I checked I found the car idles (sat in driveway at idle for 1/2 hour) and accelerates with no problems. I did notice, however, that everytime I quickly lifted out of the gas pedal the RPM drops to about 500rpm. If I start the manuever at 1000rpm then it will definitely stall (drops to 400-500rpm then down to 0rpm). If I start the manuever at 2000+rpm then it still drops to 500rpm but recovers and doesn't stall. Doesn't matter if I'm in Park or Drive.
I've already removed and cleaned the Idle Air Control Sensor with no fix. Checked for a vacuum leak (using carb cleaner on hoses and fittings) and don't see any. Going to take it to Autozone to check codes tomorrow. Looking through forums I see MAF and TPS as possibles...but I got a feeling you guys are going to tell me crank sensor. Most of the forum posts regarding CPS sound like static problems (i.e. dies at idle). My issue is definitely related to transient pedal movement - only when backing out of the gas pedal. Just wanted to check. Any thoughts?
