interchangable parts list
Mayja
OK so I'm looking to find coil springs and struts for my 06 Grand prix. everything ive found so far either lowers or rides stock height. i need either heavy duty or something that sits above stock height. i have an extensive audio set up and it weighs on the rear coils and struts alot.
I don't know about the 04+ cars but for the 97-03 guys where the rear sags I think that some people go with GTO spring isolators to give them a little raise.
Or just go with some airbags
PLEASE tell me your cars not painted like that for real!! Maybe if you were santa clause you could rock it. :th_nervous:
dude as much as i would like to go back and forth with quams and what not. i would seriously hope you have something better to do with your time than be a judgemental annoyance that offers no help i mean you did learn more than that in the service right.
on another note i was looking into the spring isolators and i dont know if the will provide the right solution as it sits the travel on the struts is too much or i dont have enough resistance in my coil spring because with excess weight its casing the car to bottom out on my tires.
so i figured either stronger coil or stiffer strut maybe even the combo will have to be done
i dont know how much it is but theres a few people in the stockton area that make springs any size and spring rate you want
good to see more cali folks on here
just take opinions as they are theres alot of them on here
intrigue springs will raise it up some or rear cargo coils from moog
Part numbers might not work. Kinda old
Front Springs:
22133031 FKN Highest Rate
22133030 FKJ compG
22133029 FJT
22133028 FJS stocker for 99gtp
22133027 FJR Lowest Rate
Rear Springs:
10258880 TDJ Highest Rate come on 04+ comp handling package
10258879 TDH
10276574 TFY stock rate for my 99gtp
10276573 TFW Lowest Rate
