What size spacers should I get
MrPoopyButthole
#Billsnamechangessuck
What size should I get to push them out 10 or 15?
I need to go another inch lower
When we rolled my fenders it pulled it out a little
I plan to try and go lower, don't know how yet...maybe coilovers
but I have my fenders all rolled flat, so the skies the limit, I'd like to push it out and have the fender barely just covering the tire and all you can fit between the tire and fender is 2 quarters
How are the coilovers for these cars...I was planning on doing the ZZP control arms with them and doing a full spacer kit for the engine.
oh my lord i love your car. put a small spacer in to flush it for now. when you lower it more youll have to figure out if you can still run the spacer or not. i have yet to see someone hellaflush a gp and so far you're doing it the best out of anyone. i would like to see you push as far out as you can without having to run any negative camber, or as little as possible.
if it didnt have those rear louvers id like it a lot more even though those are the beneficial part of the hood. i always liked my stock hood.
id get 15 mm spacers i think it looks good that height man, low without looking bagged.....couldnt you run intrax springs? i think it looks perfect and im loving what you did with that front fascia....gotta agree with the led strip tho it looks cheap....your good with headlights put some in the lens like an audi and it would look orgasmic, curve em instead of a straight line.....do the below design but start above the projector :)
http://www.fourtitude.com/news/uploads/Industry_Tuner_News/037__scaled_600_003.jpg
(led eyebrows in a way) i will love you forever lol
gimme some intrax and ill be hella flush my front clear with about 3 mm no joke if i hit a hard bump with the wheels turned i baby scrub :) my rear got a lil more play however....
I would personally wait until you go lower to go with the spacers. I plan to run the ZZP coil overs and tubular control arms on mine ( this coming winter project). I will then add spacers to mine to push them out.
PS....stretched tires are the gheyest thing ever. I like some meet on the rim.
