Need troque specs, replacing trans
GPspool
For a 05 Grand Prix L26
Can someone tell me where i can find the torque specs for:
- Trans to motor bolts
- Half shaft bolts
- Diff cover bolts
- Torque converter bolts
- Other???
Any last minute advice?
Thanks!:)
im not gonna lie, i didnt use any torque specs or a torque wrench at all when i did my transmission swap. most of that stuff is good as 'tight'. stuff in the motor and transmission is more specific.
:eek: Even for the half shaft and the torque converter!
i'm installing over $5.5k in my car....I wanna make shure nothing breaks because a bolt came loose or breaks
Trans to motor bolts: 55 ft lbs
Half shaft bolts: anywhere from 118 to 159 depending on the year. for your year its 118 ft lbts
Diff cover bolts: n/a
Torque converter bolts: 46 ft lbs
FYI, 40-50 ft lbs is what most consider "tight" so nick was pretty close minus the axle nut.
WOOT! WOOT!:th_thumbsup-wink:
GREAT THANKS MAN!!!
I just spent all day looking everywhere! For the 04+ the information is rare...
The only reason you'd swap is if you're putting a trans in that didn't belong aka it has a different bolt pattern since its for a different engine with a different flex plate.
BTW, dont worry, i'm not the one swaping the trans, i just needed the torque specs because the guy doing the job didnt have it, is there anything else that will be remouved that need a specific torque?
-tie rod end?
-ball joint?
-end link?
