Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The site migration is complete! Hopefully everything transferred properly from the multiple decades old software we were using before. If you notice any issues please let me know, thanks! Also, I'm still working on things like chatbox, etc so hopefully those will be working in the next week or two.
it aint staying at 22 degrees I can assure you of that. 22 deg BTDC at 4K would cook your exhaust valves and probably not give enough power to go any higher.
id assume our engines are seeing 40-50+ deg of advance near redline.
Wow, all these years I was looking at timing advance backwords. I always assumed under load you had more advance. It looks like you can run 40+ deg of advance but not under load.
And at the same time, I think the long mystery of why my 87 grandprix pinged BAD even on 94 octane is solved. I swapped out almost every part even the ECM at one point, it still pinged. I even swapped in different metering rods and had it rich to the point it smoked a decent amount floored, still pinged. And we're talking it pinged to the point it sounded like a diesel.
The more you opened the carb, the more it pinged. It didn't ping idling, or under light load\cruising. The ONE PART i never changed was the vacuum sensor. I bet it wasn't retarding the timing as the vacuum dropped (load increased)
