new mufflers
anybody heard dynomax? a friend of mine is giving me a set, i hope to have them mounted in a week or so
Why do all those mufflers have tha tip discolored?..I don't get that. i seen a kid with a set of those on a mid 80's camaro. i d^%n near cried..
"the ****ty honda engine and bad workmanship does it."
Ok normally I would just ignore comments like this but,
We have a 2006 Saturn Vue with a Honda 3.5L 60 deg V6 in it. And if anything it makes the 3800 look really bad.
its 250HP N\A with a very nice torque curve. Tho what would you expect from 10.5:1 compression (on 87 octane) 4 valves per cylinder and variable valve timing with aluminum heads and block.
Not only this, but it also sounds better then a 3800 especially above 4500rpm where the valve timing changes.
Don't get me wrong, I bought my GP because it had the 3800 III in it and I knew it was reliable. But to insult all Honda engines when some of their V6's are amazing seems wrong and ignorant.
And you got the dumbed down version. :th_nanana:
dumbed down version of which? :)
my 3800 III is N\A so that in a sense I guess is dumbed down.
And the Honda J-35 in the Saturn vue is SOHC and only changes exhaust valve timing so that in a way is dumbed down also :) I think there are DOHC variants doing 270-290hp.
The honda. :th_thumbsup-wink:
