Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The site migration is complete! Hopefully everything transferred properly from the multiple decades old software we were using before. If you notice any issues please let me know, thanks! Also, I'm still working on things like chatbox, etc so hopefully those will be working in the next week or two.
k so i just finished installing. ill get pics asap, i still havent found my digi camera... one question though... are my park/signal lights supposed to stay on all the time with these? blinkers work .... but they stay on when not using using my blinker.
really simple... splice projector inverter box wires into park/signal lights. use the styrofoam packing they sent to stuff under bumper cover to get them sturdy, without styrofoam they are really flimsy. at least on my car they were... took me maybe 30 minutes tops. only thing u need extra is electrical tape or wire nuts.
F*CK ALL THAT... im sending these back... im thoroughly disgusted with them. i took them apart to try and stiffen mounts up and they are cheaply made.. if all projectors are like this id rather stay stock.
id recommend nobody buy these lights... mine are in about 20 pieces in the front yard. took one f*cking light out to adjust brackets.. hooked it back up just like i took it out. signal lights make halos flash now... so yea i snatched it out and stomped the pos ******* it im pissed.
i think you just dont know what your doing lol.....i had some b4 and they were fine needed some modification but you must have did something wrong,the bracket is annoying to assemble and diassemble but not that bad....
yea, im an idiot. i installed all of my stereo equip, put 3 transmissions and a motor in my car. i got the bounce to pretty much stop. the thing that got my blood pressure boiling was the fact that after i took them out to fix bounce issue... i reinstalled the exact same way i did the first time. both sides of halos flashed when i turned my signals on...so i flipped inverter wires around... still flashed. heres a email i got in response to telling them the probs i was having.. seem like real intelligent ppl.
Dear Customer,
All headlights are design with their most reasoning spot, of corse not all adjustment will be at a better spot where it can be reach at, but a smaller tool will definity help. The projection headlights is design to give you a flat straight aim in compare to headlights with no projector. In a while view, you might find your oem headlights brighter, but projector concentrate the lights, so there will be less spotty lights. Please let us know if you have any other questions.
Thank You
Protuninglab
ok so i got really stoned today after work to cure my patience and temper issue, decided to see what i was workin with. the damage from my anger issue wasnt as bad as i thought. i got everything put back together and installed... still had halo's flashing with signal light. took everything back apart and inspected all the wiring and there was a short in the inverter box wires. pretty much did the club GP bounce mod on the lights and they seem alot firmer.. going to get some thicker weather stripping to fill in the gaps and hopefully give them some added support.. just have to wait til dark to go for a drive and see how they are.
still bounce but nowhere near as bad..gonna do weatherstripping this weekend. gotta do soem serious adjusting... but they ok i guess. i almost wish i had went with smoked stock headlights. IMO and i said IMO.... they almost look kinda ricey.
