BoostJunki3
Needs A Turbo
how does the steering wheel come off? i want a thicker on out of the 02/03's or even better if the newer 04wheels cans bolt in thatd be sweet any help?
ditto
You have to disconnect the battery, wait at least 10 min. and then there are 4 10mm nuts on the back of the steering wheel, they hold the air bag in. From there you pull out the air bag and you see the clock spring, take it out and then a nut holding the steering wheel on and then you use a steering wheel puller to take it off. Simple.
