So i purchased a 6000k 35w HID kit off of ebay. Maybe this was a mistake, but for $40 dollars i figured i'd give it a try. My problem is that after I installed the kit with a relay harness, i get the flickering. This happens when the car isn't started and when it is. It looks exactly like this: YouTube - HID twitch flicker
It happens on both bulbs. I tried just hooking the kit up to stock harness without the relay and it didn't work like i figured. I also noticed when i was driving today that when the headlights were on my DIC and where the temp is displayed flickers as well. I tested the battery and its putting out 14.4V. I checked and made sure I had a good ground with bare metal and I do. Everything is hooked up correct because I have checked it like 5 times. I switched the left ballast to the right and vice versa with no luck. Is this just a faulty kit? Or is there a possible solution to this annoying problem? Thanks in advance for the help.
