archemedes
same letter I received today
GTPLuv and others....I received a pre-notice of the recall in the mail today. See attached scan of letter received. I'm expecting official recall letter. I had the valv ecover gaskets replaced two days before the notice. Instructions with the recall should include reimbursement process for already-fixed gaskets.
Long Live the Buick Grand National/Grand Prix GTP,
Tom
Well in all fairness, Im not convinced what they stated as the issue is really the issue. First off, motor oil leaking out the valve cover gasket is not going to just spurt out with hard braking, thats a bit of a stretch there. Unless the oil is just gushing out in which case there would be other issues. Next, motor oil even with the maximum allowed 2% fuel dilution still has a flash point approaching 300*. Good clean quality motor oil is going to have a flash point much higher, appraching 450*. Fire points are approaching 500*. Oil just does not ignite that easily and even if it does it does not burn well enough to sustain that kind of ignition with that little oil. Next, the oil would have to ignite, burn hot enough to light up the plastic tray the point out. Now, you and I know that that plastic is not going to ignite easily either as it is intended to survive a hot climate being that close to the manifolds.
And I base all this on stagnant air flow. It doesnt take into consideration of any vehicle movement that would cause air flow of any kind. Thats just going to make the ignition and sustainability of any fire that much harder.
Basically Im just not convinced that the valve cover gasket is the issue. I would say best case scenario it would take an extreme set of circumstances to generate that kind of fire from oil 'drops' as they stated. And they are citing what, 1 in a 1000 cases or something like that? I dont buy it.
