Not quite sure but looks like I'm missing a few parts :th_scratchhead:
Transmission decided to take a **** on me so I figure this is the perfect time to go ahead and pull everything and do a little cleaning. Lost all of 3rd gear, and stalling the engine it would rev over 4,500 rpm's with some grinding happening. Having a rebuild done on it with new torque converter, new hardened 4th shaft, transgo shift kit, high energy bands and a couple of other little goodies. Should be plenty for a DD with a few passes at the track every summer.
Started disconnecting everything the other day but didn't get to finish cause of work and the weather. Yesterday was nice so I got back to working on everything. Only took about 3 to 4 hours of easy working all together to pull both the engine and trans separately. Gonna go ahead and replace a leaking oil pan gasket and a few other miscellaneous gaskets and O-rings.
Also plan on making my own vaccum lines running between the LIM, map and whatever the other end goes to.
Any way on to the pics.
Before starting
After pulling the engine.
Somethings definetaly been leaking.
And about 20 minutes later.
Before starting
