minichopper6hp
Banned - Busted For Scamming
Thats what i am saying l36 block and you will be fine. The main thing i would suggest to keep from killing it would be headers.
Yea that will be fine. I was just trying to say that factory front manifold and dp = boom on higher compression.
I wouldn't run a 3.4" on high comp unless you have a cam or intercooler of some sorts. Keep the stock size and turn up the timing
No worries, the 3.4" isn't even going to be considered till I get plenty of other flow mods, shooting for stock size.
Smart man...you don't need more boost with the upped compression...the point of high compression is to make all that power with half the boost
so "in a perfect world" the high comp would be roughly two sizes/one "step" behind the low comp? Similar to a Gen V versus Gen III?
No I know I'm just being sarcastic lol![]()
High Ratio Rockers – Thankfully GM made one thing simple…pushrod motors!! Stock GT/GTP cars came with 1.60:1 or 1.66:1 Ratio Rockers from the factory. There are a few choices that you have here to make some more power by letting those valves open more...
