geforcextreme
I purchased a Gen V with an unknown amount of miles. All I know is its a 04-05 model. I tore the SC apart so I could give the housing to my buddy to get the H-bar removed.
Well the bearings and the coupler are actually in great shape. I was going to buy a new SC coupler however being the OEM one is still very tight should I even bother? Being I already have it torn apart, most likely will.
Now the rotors are coated with a nice layer of carbon/grease I guess most likely from the stock PCV/EGR. I would like to degrease the stuff off the rotors but not sure what to use on it.
Should I just use a watered down mixture of degreaser or citric based degreaser and spray the rotors down?
Also as far as the bearings go, should i put a little bearing grease on the end of the rotor tips before sliding them back into the bearings? I am just not sure if bearing grease is ok to use? Its just when I clean the rotors off, any grease no the tip of the rotor blades is going to come off.
When I re-seal the snout onto the SC housing, is high temp red RTV stuff fine?
Do I only apply it to the snout side and not the rotor pack assembly that bolts onto the SC housing itself?
Do I need to apply any thread locker to the snout bolts?
