turbocharged406sbc
gotta love Gm two different spellings for the same word...
anyways getting reall close to firing up Al's Jyard hauler/DD
(former) 2.8/125c car
lots of small custom sh!7 :th_laugh-lol3:
machine down 440T4 hall effect VSS housing to make a 3/16ths spacer to bolt the 125c mechanical speedo housing and gov shaft into the 440t4, worked perfect, even counterbored the 440 sliver to locate the 125c housing
reworked (cut weld/spacer) broken rear mount to bolt to side pan of 440t4 (left it broken
removed rubber mount from front mount, cut and welded it solid
since it was locate 1 inch farther forward.
moved diff to engine bracket over to the other holes in the block, fit perfect, left 1 bolt out:th_laugh-pointup:
deleted pan sump for the trans ciculation pump that was used with it from when it was in the rear of the 442.
put in the 2.8l/125c TV cable
rework trans cooler lines from 442 install to work with D side radiator fittings
rewired 440t4 5 wire round connector to the 125c's harness
now lets see how the great rig fest turns out...
X yer fingers folks, smoke test's comming up...:th_laugh-pointup:
