i have a question about the traction control. is there a way to reverse the control so it is off all the time and needs to be turned on manually?
EDIT: Go here:
http://www.backinblackgp.com/TRAC_Button.htm
also, my air bag light is always on, normal?
Uhh...no. It should have a DTC associated - you can go to any AutoZone or Advance Auto Parts store and they can pull/print the code(s) for you. Could be:
DTC 13 Driver Air Bag Deployment Loop Short to GND
DTC 15 Driver Air Bag Deploy. Loop Short to V
DTC 23 Pass. Air Bag Deployment Loop Short to GND
DTC 25 Pass. Air Bag Deploy. Loop Short to Voltage
DTC 31 Driver Air Bag Deploy. Loop Resistance High
DTC 32 Driver Air Bag Deploy. Loop Resistance Low
DTC 33 Pass. Air Bag Deploy. Loop Resistance High
DTC 34 Pass. Air Bag Deploy. Loop Resistance Low
DTC 75 Driver Side Air Bag Short to Ground
DTC 76 Driver Side Air Bag Short to Voltage
DTC 77 Driver Side Air Bag Deploy Loop Resist High
DTC 78 Driver Side Air Bag Deploy Loop Resist. Low
DTC 85 Pass. Side Air Bag Short to Ground
DTC 86 Pass. Side Air Bag Short to Voltage
DTC 87 Pass. Side Air Bag Deploy. Loop Resist High
DTC 88 Pass. Side Air Bag Deploy. Loop Resist. Low
Or...something like that.
-Swash
