hhahahahahaLOL Look at Captain Obvious up there^^![]()
hmmmm lets see.... im going by what happened... purolator oil filter failed... no name oil filter failed.. mobil 1 didnt fail... ive never seen anything like this happen before... so unless u wanna come diagnose what happened dont tell me what is and isnt the cause of my motor being f*cked.so just cuz the standard priced purolator couldnt handle the higher pressures the top of the line mobil 1 could, the filter must be the cause of your entire engine failure??
yeah right
If its getting a newer motor, why try and fix the the old one?:th_scratchhead:
I've run nothing but Fram or Wix since that day. Just my 2 cents.
Wow, switched from Purolator to Fram. Talk about a step backwards.
by chance is there two gaskets on there? like the old gasket got ripped off and was still there when you screwed on the new filter?
haha no sh*t
purolator is known for 2 things. quality, and customer service. if you can prove the purolator filter was the cause of the engine failure (which i dont think you can) purolator will buy you a new engine. problem solved
