Problem With BBV
Bedwards
Hey guys. I just received my SS M90 kit, and I noticed that the plastic tabs holding the boost bypass valve actuator to the bracket have broken off. The actuator is loose and not secured. What can I do to fix this? Do I need a whole new piece? I've heard if you take it off, it messes with the alignment of it, and the valve won't function properly. I attached a few pictures to explain what happened. Thanks.
Epoxy it? I don't think there's anything special about those tabs, as long as you get it secured, you should be fine.
