minichopper6hp
Banned - Busted For Scamming
Why the hell does zzp want so much for a crossover and downpipe? Its ridiculous, $500 for the crossover, another $600 for the downpipe? Thats crazy!!! Oh well, looks like ill be making my own.
Unfortunately i dont, sorry!! Cant you buy a new tog crossover? What is damaged about it?
No one else makes them, zzp could charge whatever they want. The crossover is also only $250 unless you want the version with the wastegate on it. You could easily go open dump wastegate and run a 2.5" downpipe, which would equal out to your typical 3" downpipe setup.
What type of steel are you using? Your going to want the smaller brake booster for a 3" dp as well.
In an open dump setup, your not returning the exhaust gas or pressures to the downpipe. So the downpipe turns into more like 2.5" downpipe + size of wastegate. It's also better at keeping a consistent psi. The only thing you have to deal with is the noise, which isn't too bad.
I understand where you are getting the idea but how do you equate running a open dump wg to relieving .5" of space from a 3" dp?
1. The $250 crossover is a retarded design. 2. Im going 3" dp, not open dump.
