supercharge pully replace
kollo
hey has anyone on here replaced the couplier on there super charger? mine is making noise, and i was told in order to change it i have to pull the whole nose off is this true? and if so is it alot of work?
thanks in advance.
easy should only take ya a half hr. if that, get the coupler first and the oil they are hard (sorta) to get most of tyme there outa stock
1 take belt off
2 unbolt snout
3 pull snout off remove old coupler
4 put new coupler on
5 line snout up with coupler dont force it should go on with ease if lined up properly
6 make sure you put sum kind of sealant on snout (can get at gm).
7 bolt it up
8 fill it up with the special blower oil (can get at gm)
9 put belt back on
10 you are done :th_thumbsup-wink:
What he forgot to mention is the oil in the blower is some nasty smelling sh1t that you might not want all over your engine
If it were me i would take the blower off to do it
but that would mean pulling the injectors and fuel rails
my bad oil does smell discusting ,but nuthin a lil degreaser and water wont take care of:th_winking:, i usally suck it out with a sucsion pump but not all ppl have access to one
i replaced the SC oil this weekend i had the entire upper intake off and just turned it upside down on my work bench took like 2 mins to drain out. smelled Horrid.
takes about 8OZ's to fill FYI
