just outa curiositty u have the oring and the spring on the pcv valve right?
If it rattles... its probably good.
Contrary to popular belief, the buildup you see on your oil filler cap is absolutely normal. Especially when you have short trips and the car doesn't get to warm up often. Everyone says your fuked and you have coolant in your oil doesn't loook under their filler cap often enough.
If you notice lower coolant levels, white smoke on a constant basis from your exhaust, or milky oik changes....then you need to worry.
are you sure its white smoke or is it just condensation?
also it may be the cap and now your driving in the snow and getting water thrown at the valve cover...isnt lake erie weather great?
well ever since i had the car i thought it was a little too smokey. especially when it's cold.. there's a decent amount of white smoke.. i just wasn't sure if it was normal for a gp, i haven't had anything to compare it to.. and i almost always warm up my car first.. so i think im fked.
dexcool has nothing to do with it. its 100% poor design. look at these pics and tell me its NOT poor design....Yep, Because the Dexcool eats the plastic.
