fatride...did you have the tell-tale "grinding/propeller" sound when driving?? of just the light on?
I have the same problem, just had it scanned and got the codes CO550 and C0244. I think its my ebcm. sounds expensive... any thoughts?
Mine actually just started this a coulp days ago...FML.:th_shakinghead2: when ever I Decel from higher speeds it sounds like grinding fan. and my ABS light goes off and on. Does this mean its one wheel bearing or both? and how can I find out which one it is....Probably should just take it to the shop but shops tend to say more is wrong and charge more...
if you have a growling sound chances are the wheel bearing sealed bearing has gone bad. Alot of times those puppies come out in two pieces when that happens.
