Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The site migration is complete! Hopefully everything transferred properly from the multiple decades old software we were using before. If you notice any issues please let me know, thanks! Also, I'm still working on things like chatbox, etc so hopefully those will be working in the next week or two.
General rule is .008-.012 of clearance per friction. So if the input clutch pack has 4 frictions, you want their to be .032-.048 clearance. You can adjust this pack by getting a thicker snap ring if its a bit on the loose side. I personally run 5 frictions in my input clutch pack with thinner steels which are .050 instead of the stock .076.
For 2nd you can run the stock clutch pack tolerance but sub 2 of the standard .068 steels for 2 of the .090 steels.
For 3rd I run the stock raybestos z-pack
4th stock stack up as well.
I run all raybestos performance stage 1 (red) frictions for 1st, 2nd, 4th, which are great for higher torque/hp applications and still good for DD which is what I use my car for.
You'll want to mod your spacer plate too if your panning on pushing some major power
