97-03 gtp air/fuel ratio gauge
dont even put it in unless its a wideband. my narrowband pulled enough voltage from the signal wire that it was screwing with my fuel trims. unhooked the guage and presto.
the only way to truely use an afr gauge is to wire it into a completely seperate o2 sensor, or if your not running a cat, wire it to the rear one, and get a wideband. if you get a narrowband and hook it to the front 02 sensor youll seriously never get it tuned. itll pull enough voltage from the signal to the pcm that it will whack out all your fuel trims. its a tuning nightmare plain and simple.
