Helloooo.. I just purchased a 99 GT and am getting some minor things fixed that I want to take care of. I have done some research about similar problems people have had but just want to ask if anyone could help.
Two days ago, I took the dash apart to modify the XM satellite kit to work with my iPod. That went smoothly, but I realized when I was putting the dash covers back on, I had pulled a single black wire out, which led out/in from just above the floor trim on the drivers side by the door hinge (I'll take a picture tomorrow).
Since then, I've had some trouble with getting the car to shift out of park.. the release on the shifter won't budge but I can hear a click in the dash when I press it with the brake down. I'll turn the car off and on two or three times and then it will release like it normally should, and I can get into gear and it drives fine. I've read that this could be the Ignition Switch or Ignition Switch Module (if there's a difference?) My heat Blower also only works on 5 'MAX', which I read is (somehow) related to this too, but that was always not working. I'm hoping that wire is suppose to lead to the Ignition Switch but I could be wrong.
Any Suggestions??
Any Suggestions??
