minichopper6hp
Banned - Busted For Scamming
i sell fullsize phenolic cores if you want give me a pm, very reasonably priced at much less than zzps unit.
Logan
Logan
Yea, tune yoru car OFF meth. Then when you put it on set the start point to around 3psi and ramp it up to say 8psi. This should get it to start spraying before you get Kr and keep the iat down so that kr does not show up.
Main thing with meth is don't go by the if a little is good more is better mentality. Most m90 cars will run best with a DO3 for low modded. r DO5 nozzle for the more moded setups.
If you use a boost reference progressive controller on a Eaton or for that matter any roots or twin screw supercharger. Your not going to get much of any progressive feature out of your water methanol injection system at all.
These superchargers go right into full boost when you nail it. The same thing is going to happen with your progressive controller. It going to zip right past the start point you set and hit your max setting sending the system into full flow. The company who sold you that water methanol injection system should have explained this to you and just put you into a Stage 1 system and saved you some money.
If you want a progressive feature, which by the way you probably really don't need, they should have set you up with a 0-5 volt controller and based the injection off of your mass air signal. Not a boost signal. Then you would get a true progressive feature out of your system.
Plus, the reality is you don't need any injection at 3 psi. You can run these engines just fine to 5-6 psi on pump gas with no water methanol injection. If you set it to start spraying at 3 psi your just going to end up using a lot of fluid with normal around the town driving.
If it were me i would use a simple and less expensive Stage 1 system with the switch set at no earlier then 5 psi (if your running 8 psi) that way you offset normal around the town driving.
Rodney
Plus, a number 3 nozzle on these non intercooled engines is too small. Pull air temps and you'll see it will only drop the air temps 30-40 degree's from it's normal 220-240 degree's at 8 psi depending on the ambient temps of the day.
Sort of like that, this will be done here shortly (1-2 weeks) give me a month or so for tuning and other issues that may or may not need to be taken care of and i'll be able to post back with results whether they are good or bad.
