i am looking into making my own sub box and i want to put it in the back right Corner of the trunk. i was wondering if any one has done this?
if you run a second battery then you definitely need a high output alternator. But why are we talking about this, my friend that was running 2 batteries was rated at 4000 real watts, he NEEDED that extra battery lol
A cap is very good to have, especially if you're running a high powered system. A capacitor works by using it's stored energy to supply the amp. Say you have a bunch of really fast, heavy notes, it's gonna take a lot of energy to supply that amp. Instead of pulling it all form your car's battery, it takes it from the capacitor making it easier on the battery. Then all the battery has to do is slowly "refill" the capacitor.
Okay... did you guys know your amps have caps in them to stabilize the power rails inside them?
So... if you have a properly built amp, the internal components will do the same as your suggested cap. So if a cap helps you, get rid of your amps.
Boxes... if you're concerned with them making noise, make them structurally sound by BRACING and RE-ENFORCING them.
Batteries only help when the voltage drops to 12.5-13 V where you shouldn't be because you're damaging your alternator at that point.
Point is, alt is what powers everything in your car when its on, so don't think all this other bull**** is going to help you when you have nothing to charge it with in the first place. If you have enough to charge that ****, then you're better off not charging it and using that energy in your amps.
ok well i got my box all made now i just got to find a way to get it in the trunk. but now i have to get and amp i am looking at the kicker zx1000.1 or the zx550.2. or if you know any amp that would work better let me know
on your note about charging, of course with a huge draw you need a upgraded alt, but if you run a small power cell, it will never drain enough to where it causes voltage issues. If it does your draw is big and upgrade your alt. I popped my inline at my battery in my S-10 and it was without a charge for about a 4 days or so, it took about 2 days of daily driving until i noticed a difference in loudness or quality with there smallest cell. Also i'm running an old 800.1 Bazooka Mono amp, rated at 400rms on 2 10in. Memphis PR series
If you're running 1 sub, off the top of my head i would say go for the 1 channel. Since the type R's are dual voice coil (I assume 4 ohms per coil) get yourself a good Class D Monoblock amp that is 2 ohm stable. Wire the voice coils in parallel to create a 2 ohm load on the amp. So for your question about the amp, i'd go with the zx1000.1 of those two, although what i just described is what you should look for with any amp. Remember, research is your friend.
wtf is a power cell?
The battery, does NOT discharge at the normal operating voltage in your car, it charges. Therefore it can't help you unless your alt is insufficient for the job you're asking it to do.
at the comps they run deep cycle batterys and have upgraded alts but a upgraded alt is needed before anything else(besides the big 3)If you've never heard of a power cell you've apparently never been anywhere around car audio. Look at ANY competitive system, and if there not running multiple deep cycles they have power cells, which is basically a deep cycle battery that you add on to have stored power, like a cap that actually works basically. Don't dis it unless you know what it is and how it works, cause it works, and thats all i know. My lights dimmed with a cap and now i have plenty of power for everything with no issues. And on top of that i don't run enough to upgrade my alt so why spend 300 on a alt when i can spend 100 on a power cell and be done with no issues.
