jdm turbo kit
idk i considering the kit myself seems kinda weird a lil to good to be true but ima keep doing my research on it before i completely ignore it
And push at least 25 pounds of boost. :th_thumbsup-wink:
Ok, pretty much what they're trying to say is it's basically useless. 90% of the parts you'll need aren't there, the parts that are there are very cheaply made and will break very quickly, and it will require LOTS of custom fabrication to work. You'll end up spending more on that p.o.s. turbo that you would've on ZZPs by the time you get it working.
If you're looking for a less expensive solution to boost look into a topswap, or an L67 engine swap.
no name turbos for the loss. i would never put anything less than a garett or turbonetics on my car.
