Will these work??
you need a scanner, after you put everything on EXCEPT FOR THE PULLEY you need to scan. If your at 0, drop a pulley size and see where your at and go from there.
You've been on here long enough, you should know all of this by now...
i know iron im just saying i dont see how with all the supporters i would have more then 2* if that of knock? w.e we will find out next month when i get the tune n stuff
BACK ON TOPIC will the plug wires work i believe they will idk if im awsnering my own Q but i think they will any input? if not its cool
Just don't be set on running a 3.4. I have a lot more mods than that, but I am knocking a lot and need to get my tune figured out.
I would just get some designed for the 3800 so you don't have a lot of extra length hanging around the engine bay looking like ass.
1. get wires ment for your motor, or have extra wire hanging around up to you....
2. i have a 3.4 on with 2 deg or less of kr and im pretty sure somethings taking a shyt under the hood....hopefully not....2 deg or not knock is dangerous
youre just plain silly. i cant convince you in any other way to not screw up your car, but you have your own agenda. i will no longer give you a lick of advice because you just dont ****ing listen.
i dont understand...... your right bio..... every1 seems to have a 3.4 setup but for some reason i cant..... in your view what would be safe to run a 3.4
I said im getting a custom tune im getting a 3.4 im going to scan im getting a 3" inch exhaust and i ported my pems and t-body already a 4inch intake and possibly r1.8 or 1.9 rockers how is that not safe?
