minichopper6hp
Banned - Busted For Scamming
Air density changes with temperature, thus the need for an IAT.
think of it this way...
Your fwi sucking in air only from the fender, through bends in piping with slightly colder temps, blower heats up air anyway.
OR
You run right off the throttle body, completely non-restrictive, no bends or anything, air getting pulled in is warm, blower heats up air anyway.
Thats what i thought is it had some kind of reason for being there. So wouldnt being just ziptied out in the open give it improper readings? I would think it would need to be somehow incorporated into the actual airflow of the intake like normal to get proper readings allowing the engine to run optimally? Correct?
Why do this Bio? Did you not monitor intake temps at all? an doesnt the iat send some kind of signal to affect the tune depending on temps or is it just strictly reading the temps just to read them?
