smokingjoe
is there an easy way to disable lockup function of the torque converter?
maybe somthing with brake switch.
To the orginaly poster. If you have no tuner there is a plug in the front of the trans near the top of the case on the side were the exhaust cross over is it should be a round plug plugging into the trans pull it and lock up is shut down and no codes will be tripped. Because tkere will be no power going to the tcc switch. thats the cheap way to do it if your in a fix...
i have a shift kit and trans interceptor to increase line pressure, and when ever it goes in to lockup there is an annoying jarring type shudder, but i am very pleased with the rest of the shifts.
i am not worried about gas mileage.
thanks trannyman in advance
Joe Gancos
FWIW, I kinda think I know where he is getting this info from. On my 440-T4, which was NOT electrically controlled, but rather vacuum controlled, I could pull the wiring plug on the front of the trans and disable lockup without any problems. So if his name is correct, he may be able to do the same on his 1992. But there is no way you can do this on a 97+ GP.
that's what we're getting at. the topic clearly states the op has a 99 MY. 99 MY GS=L67=4T65E-HD --- these are facts. and immediately he says unplug the connector and it will do what you want. obviously he doesnt really have any clue about these transmissions. It'd be one thing if he asks if it has a separate electrical plug, or asks specifically which trans it is...
i'm sure he knows stuff about the gen 1 cars. that's fine. but to assume that one knows about all transmissions in these late model W body cars too... sorry, charlie. do your homework.
What Zef said is 100% correct. If it is all in town driving then its not really going to make much of a difference, but highway driving is not going to be that good on the trans or fluid as locking up the converter gets rid of the converter slippage which creates heat, not to mention the few mpg you will lose. Out of curiousity have you tried unplugging the Intercepter yet???? I would try that. I have one here that the output transistor that controls the lockup solenoid was burned up and I can see that causing a lot of grief on the circuit and possibly causing what you have going on. Also there is a delay control for TCC in that box, have you tried adjusting that?
the pot for adjustment is still there.
