im in the process of installing a new motor as the old one is developing a bottomend rodbearing. well i had to remove the oil filter housing on the new motor to be able to drop the new motor into the car. i cleaned the paper gasket on the filter housing and since i did not have a replacement paper-gasket, i just used the gm rtv gasket and laid a bead along the edges where the old gasket existed. is this ok to use or should i unbolt the filter housing and order an oem paper gasket from the dealership? i also used teflon sealant on the 4 bolts. any advice and suggestions is greatly appreciated!
