SyntheticShield
Good Lord James, you have got to get your notebook legible so I can start reading it whilst I put it on the internet for everyone else. You are just chock full of fantastic information.
Update: I performed the steps as required. Now I get two codes
P1404
P0403 -EGR Solenoid/Circuit malfunction
I did some research and it appears not so much to be the EGR but the "motor" on it(?)
Another issue could be a bad ground.
Research still indicates replacing the EGR won't fix the issue. Suggestions?
This has gotten really annoying.![]()
EDIT: The "Motor" is I believe was for a Nissan, so you can scratch that off.
Page 63 of the document shows a diagram of the EGR. Does this help? No. Just showing it.
http://www.autocenter.weber.edu/obd-ch/presentations/OEM-Evap-Cat-EGR-RespFinal.pdf
Called the dealer.
Get this. They want $240 for that small plastic piece.
This is officially the most overly priced item I've heard form a dealership.
They're out of them.
Called another dealership and they are $6.00. I'm pretty sure that other dealership got it wrong then.
I should be good to go now.
last update:
Replaced hose and small plastic piece. No more codes. Code free is the way to be.
