Amp Wiring
DDPeppa
2 quick questions, i have a 98 gp and i was wondering how some people bypassed the firewall and where they did it, and do i connect the amp power cable to the positive terminal on the battery or on the terminal on the fuse box? thats it thanks
On the passenger side straight in front of the seat on the firewall theres a rubber boot like thing, i poked a whole through that and ran it straight up and down the fender to the battery. You can do either way, depends on how much you subs will be kicking out..
like he said there's that little rubber boot/grommet just poke a hole and you just run your power wire through the the positive terminal on the battery. i'm sure you know this just make sure you put the proper fuse in too within 18 inches of the battery i believe. i can snap a couple pics of the grommet if you need.
yeah that picture would be nice and yup i got a fuse there
hope this helps
i hooked my amps up exactly how windycitygtp did..if u hook it up this way (the power cable hooked up to the fuse relay box), the amp will shut off wen ur car does..so it wont drain ur batery
